Re: spun hub
Welcome to iboats, Scott. Regretfully, no. as a MOF, there are no after-market props for this motor, unless it is custom-made. They come in one pitch (15in I think), and one diameter, 11.5"----And that's all. <br />Besides, given that this lower unit is barely strong enough to handle the HP assigned to it, I'd strongly advise to stick with stock here.<br />They're designed to be the "weak-link" in the chain, to protect the L/U from gear damage.<br />As you'ver probably read allready, one way of keeping it from spinning-out is to ramp-up the throttle, avoiding "hole-shots".
