Re: The ole 50 hp Force Again
I found the original owners manual to my 1990 50 hp, and it states that spray should be coming out of both relief holes during idle. This indicates that the impeller is working. I see this happening on mine, but cant tell whats coming out the exaust near the propeller. <br />Even with the muff on, which does not cover the water intake hole and sprays all over the place, you are unable to tell if water is coming out of the exaust. Putting the lower unit in a barrel of h20, same result, cant tell. But my motor does have good spray from the two relief holes. <br />I wonder if there was a way you could tap into the water jacket to make a pee hole?<br />Also, does anyone have a breather cover on the front of your carb?, Foam or somekind of air filtration going into the carb? I dont have anything on the front of the carb, just wondering....thanks.....jas....
