My 35hp chrysler 354hc is acting up. <br />Symptoms:<br />works fine in reverse, but when in forward gear it thuds violently every few seconds at low and high speeds. If I throttle it up it will eventually fall completely out of gear and rev out of control and after a few seconds the rpms will come back down, but can't get it back in gear without adjusting shift shaft. After I adjust the shift shaft to get it back in gear, it does the same thing again. I took apart the lower unit and inspected the gears and clutch dog. They seem to look fine with no metal shavings in the oil, but I'm not sure what a bad gear would look like. I recently put on a brand new prop, but I thought I installed it correctly, and don't seem to think that's the problem, but not sure. I know FOR SURE that it is not an engine or fuel problem. I have no clue what else it could be. PLEASE HELP WITH ANY SUGGESTIONS!!
