I have a 1990 Force L-Drive 90HP. Just spent $$$$<br />Tuning and changing Parts.The motor runs Great when she is cruising.when I lower to neutral she races and revs up to 3000 or 4000 Rpm.I played with the air/fuel mixture screws and the adjusted hex nut & set the idle to 1000 RPM but she does not set right.Should I spray 10w40 oil on the large hex nuts channel , could she be sticking and not falling back to normal Idle.Why do force engines not idle properly and cut off when put into gear. I have to re-start the engine 5 times just to get off the dock.<br /><br />Thanks
