We are boat dummies, just bought our 1st boat. 85 Bayliner Capri with an 86 Force 125 hp. The tilt/trim did not work when we bought it. The motor is now working, cleaned it up, replace a spring, etc. The trim mtr has 2 wires (blue/green) coming off of it, the boat has 3 (bl/gr/black). The wiring between the boat & trim had no relays. From reading some of the other posts learned about using lawnmower solonoids in place of relay. Used 1 solonoid for 12v- & 1 for 12v+, didn't work. Should I just use 1 solonoid, if so, how do you wire that?? If you jump the ground wire back & forth on gr & bl, it will work. <br />Next problem, when this got started, the pump was completlly dry. Have since put in ATF & the pump will raise the mtr about 1/2 way up. While working on it last nite, it went all the way up about 4-5X, then it quit & would only go up half way again. Does this mean that there is still air in the system or is something else wrong? Oh, & once the mtr was raise up it would slowly start to sink down again.<br />Thanks!!
