I have a 105 hp chrysler model 1059 HD Serial 8389. I think it is around a 1969 year. I want to be able to test my own systems with a engine analyzer etc. Since I'm a beginner at this, where do the analyzer connections go to test for rpm's. I have a distributor, 1 coil. This is a 4 cyl. motor. The instruction book for auto's states "connect red test clip to distributor (-) side of the ignition coil and the black to ground with inductive clip on lead spark plug wire." Is the connection to the (-) distributor or (-) coil?
