Re: Two Battery Wire Up
To clear up the confusion.<br /><br />Yes, connecting them in series will produce 24 volts. However, the first post does NOT describe connecting them in series, even though he says "series" Black to black and red to red would be in parallel, which will produce 12 volts.<br /><br />On that note, I advise caution. Batteries have internal resistance which is usually very small, most often milli-ohms. If one battery is old, and gets weak faster, you can get one battery that is several volts higher than the other. This can be a problem, since they are connected, several volts over a few milli-ohms can produce very high current. <br /><br />So you get the "good" battery discharging into the "bad" battery at a very high rate, which can damage both batteries.<br /><br />If you are going to hook batteries in parallel, I suggest brand new matched batteries. The larger the difference in the batteries, the bigger the risk. I suggest getting two batteries both the same size and type from the same manufacturer, to reduce any chances of problems.
