Re: smoking
A 50:1 premix of gasoline to oil is recommended for all motor speeds up to the wide open throttle range for this motor. Therefore, it will have too much oil at slow trolling speeds and the motor will smoke. I wouldn't try using 100:1 premix if you were trolling as these motors were not designed for it, however, in theory this should curtail the smoke a bit.
