mcat121212
- Jun 1, 2004
- 18
I have a 98 Force 120hp. Most times when I try to start, it will fail. Takes 2-3 tries and I notice even after its warm I need to choke to start. It usually fails that attempt but the very next try, it will start. Sometimes I need to throttle up and she'll start real stonge. Also, she idles ok in nuetral but will shudder or stall in gear when approaching dock or the trailer of course. My first thought was to raise the idle but I think that would just be masking the real problem. I believe its running lean. Sounds like she's starving for fuel. (not loading up or smoking excessively). Can someone please go though the low idle adjustment procedure starting with where the low idle screws are on the carbs. I think they are on top slighly facing starbord side????(My manual has not arrived yet) Thanks
