Hello,<br /><br /> I have a question about a Force Engine that hopefully someone can help me with. The engine doesn't have many hours on it, I can say it probably has less than 100 hours over the 14 years I've owned it. The engine turns over, but it runs hot. On the outboard motor, halfway down on the outside there is are two little holes side by side. I don't know if water should be coming out of it or not. I see smoke coming out of it. It seems the engine is overheating. I had a guy come and look at it to buy and he said if you couldn't put your hand behind the motor with the cover off for like 10 seconds then there is a problem. Anyone have any ideas?
