jdparsons1
- Jun 22, 2003
- 16
Hi, I have a 1987 85hp Force outboard and i just pulled off the lower unit to change the water pump impeller. In my seloc manual it shows that there should be three parts that come out with the drive shaft on the spline, a spacer, rubber boot, and sealing ring. Im not seeing the ring anywhere, just the spacer and boot. I was curious if maybe they integrated the boot and seal as an aftermarket item and the book only shows stock or am i missing the ring? Here is a pic of what was on the end of the spline. <br /><br />
