This is a strange one. I noticed that the piece of fuel hose that goes between the 2 carbs (feed hose) was very hard last season. When I replaced the hose, the motor would not start. I put the old hose back on and it was fine. I thought I was going crazy. This year I decided to try it again. I started the motor first and it was fine. I replaced the hose and it would not start. I checked the carbs to see if they were getting fuel and noticed that the motor was flooded. I drained the bowls and sprayed a little starting fluid and it kicked. I then leened out the carbs (from 1.25 turns out to 2 turns) and it started. I have not yet taken it for a spin. Could this be why I was missing RPMs? Any ideas as to why this happened. I just put new Boyesen reeds on the motor. How leen does it need to be?
