hello,<br /> I have a 97 120 force/merc. I am posting here because its a merc lower unit,. i have a splins shaft and shift, got the lower unit off and put new impeller in. Question is...impeller was same size as old one, this one went in..it is very tight, fist time doing this, not sure if its suppose to be so tight...when start it up(neutral) with the muffs, no water comming out pee hole..any suggestions, thanks<br /> dave
