Rick K
- Oct 6, 2003
- 235
Hi all,<br /><br />My '74 Islander has twin tanks that use one gas gauge, along with a switch. I'm assuming that the valve on the water seperator is where you switch from the port to strbd tank, and the switch is what runs the gauge for each. The gauge does not work when switched to the strbd side.<br /><br />I really don't like this setup anyway - is there any reason why I just can't use 2 gauges, wiring them seperately? <br /><br />Also, the tanks are grounded back to the battery. I understand the purpose of the ground, but does this ground play a role in the gauges working?<br /><br />Thanks!<br />Rick K
