Re: 1990 FORCE 50 HORSE WHERE SHOULD MY COOLING WATER BE COMING OUT?
Joe, You may not have a problem.<br />The 50HP Force does not have a telltale. The only way you know it's cooling is it will sputter out of the two exaust holes in the back of the leg, and out of the exaust in the lower unit, just above the prop.It should take a minute or two to start this sputtering. I've often described this sputtering as "someone told your motor a funny joke with a block full of water". <br />But that being said, you just bought this motor...Change-out the impeller and the thermostat. 65buks is high, even for the complete pump and housing kit--and simply may not be needed. Just buy a 15 dollar impeller{ Quicksilver part number #47-F433065-2}, and a 9 dollar t-stat, and install them. This way, you'll know when it was done, and how many hours it has on it. Then, it should be good for another 200hours, or 2 seasons.<br />Just follow he procedure for changing it out given by Terry. If you are a reasonably handy backyard mechanic, it will take 2 hours to perform this task, and an hour the next time (you'll know exactly what to do, and be tooled-up for the job before hand).<br />The head should get hot, but no so hot that you cannot lay a hand on it for 3 seconds.
