I have a 92 90HP Force SN#908F92C. When i hvae it in neutral and push the throttle all the way up the RPM tops out at 3000. When I am out on the water and have the throttle wide open the RPMS are 4800. <br /><br />is this normal? If not, what might be the problem.<br /><br />Is 4800 RPM normal at WOT for this motor?<br /><br />I have a 24ft pontoon boat. <br /><br />Thanks for any help you can give.
