I've recently purchased a 150hp force 1990 installed the engine on a 19ft bayliner enigine runs great and strong at higher speeds the engine overheat horn goes off at lower speeds it seems to be fine after overheat horn sounded I cut the engine let it cool off returned to shore and checked compression wich was the as when I bought the engine(120psi per cyl.)I am curious since the boat has no temp gauge could the temperature switch be faulty and setting off horn at a lower temperature than it should? Is there anyway to test what temp. switch is closing at? Is possible to install a temp gauge? Thanks!
