Re: Testing compression
Here is what my manuals recommend. Warm up the motor. Disable the ignition with the kill switch. Take all the plugs out. You can ground the plugs for extra safety, if you want to be really cautious. Have the throttle opened fully. Using a remote starter switch, connected to the positive wire at the starter and to the thinner wire going to the ignition, turn the motor over 4-5 times for each cylinder. Write down the readings. If you do not have a remote starter, ask a friend to help you by turning the ignition switch. If you are concerned about damaging your impeller, continue with the earmuff water source -- on land. That should do it. More than 15 psi difference between/among cylinders is considered too much. If a reading is too low, spray some oil mist in the cylinder, for a "wet compression test." If the pressure increases, your problem may be stuck rings due to carbonation -- solved by decarboning. If the wet test does not help -- get your wallet out -- $$$$$$$$$. Good luck.
