I need to change jets on my three carbs how?
Realgun
I bought my boat from a dealer in MN about 1000 ft and I live in NM about 5000 feet boat at 4200.<br />I know I need the smaller jets as the air fuel ratio will be better and will burn less fuel. Do I take out the screws and then the jets? Or do I have to remove the carb from the boat and then install the jets? I know about the size and where to get the new jets.<br />25 MAIN FUEL JET (.074) SEA LEVEL - 2500 FT. 1 <br />- 072) 2500 - 5000 FT. This one should cover it.<br />- 070) 5000 - 7500 FT. <br />- 068) 7500 - 10,000 FT.
roscoe
Re: I need to change jets on my three carbs how?
Don't need to remove the entire carb.<br /><br />Don't know which engine (75, 85, or 90hp?) and carb you have, but you should be able to remove the float bowl, and the main jet is on the starboard side. <br /><br />May require removing the float pin and float to access the main jet.<br /><br />You may want to replace the gasket while you are at it.<br /><br />Place a plastic bag under the carb, and tape it in place, to keep any little parts from falling down into the cowl area.<br /><br />A repair manual would sure help you with this.
