I have a 1988 Force 50 /14' Bayliner that I bought in 1995. Never had engine problem no matter how long it sat. Just recently, I had a stuck float so shop recommended carb rebuild. Also time for water pump replaced, so did both. Price ended up being higher than expected for carb and shop said they also replace t'stat. <br /><br />Took it to lake and started ok but seemed to idle high. Boats were coming in so I put it in reverse. Seemed ok. Put in gear and headed across lake. 1-2 minutes later seemed to run ut of gas. Couldn't get started again. Took back to shop, now they say "sorry your cylinder died, not our fault" (compression at 25%). Shop claims they can start it with flusher but when I use garbage can method or lake it still doesn't start (back pressure). <br /><br />I felt ripped off the first time I left shop and now engine is possibly dead. Do I have recourse? Are they right that 2 mins. after fixing, it was engines "time to go" anyway???? (not that I believe that) They also claim my fuel connector was loose (never connected perfect in 9-yrs but I've been runnning it without problem) and that could have allowed air into engine.
