Re: Oil/fuel Mixture for older motors
Hi Full Boat,<br /> In general, the oil ratio you should use is the one as recommended by the manufacturer. There are exceptions to this, but for the most part you won't hurt your motor by following that recommendation. The exceptions of note are cases where the original recommendation was TOO lean, .ie late 1980s OMC kickers that were 100:1 are now 50:1, as per factory service bulletin.<br /> Take a look at my general recommendations on the FAQ section. It isn't meant to be the last word on oil ratios, but should get you going without danger of cooking your motor. <br /> Stick to the best oil you can afford for your motor, with a minimum of TC-W3 rating. Older or lesser rated oils are just that - older and inferior... Also, original recommendations for many very old motors were to use SAE 30 wt. oil. That is one original recomendation that has gone by the wayside due to their not even being "2-stroke" oil back in the day. Modern 2-stoke oils are far better at lubrication, mixing with the gas, cleaner burning, etc. than 30 wt. was ever meant tobe.<br /> Hope that helps,<br />- Scott
