What kind of speed should I expect from my combination?<br />I have an "adventure" 9 foot speedboat. (shallow V) Like the Addictor, 245, but a foot longer.<br />It came with a Tohatsu 40, and would do about 31 mph.<br />I replaced that with a Johnson 75 stinger short shaft. Hydrofoil, no trim tabs. Motor as high as possible w/o ventilating. Tach is new, speed by gps.<br />The 12.25 X 13 it came with would turn 6200 rpm at 39 mph. <br />I put on a 12.25 X 15 and now the best so far has been 43 mph at 5400 rpm. <br />I've looked at the list of props for this motor, and it seems most people run more than 15" pitch, even on the 50hp motors. <br />I've also read of higher speeds from larger boats with the same power. <br />Seems odd that anyone could run higher pitch with this motor, or go much faster, since my boat is only about 300lbs w/o motor, gets on plane at 8~9mph, and trims nicely at speed. <br />I just wonder if Im in the ballpark speed-wise for what Im running. What do folks get with 75hp on "normal" length boats? Better than low 40's?<br /><br />Thanks, <br />-Dan
