Re: triggers
You can bench test ignition coils, charge coils, and trigger coils with a common multimeter. You can't bench test an electronic ignition module. Generally, if all of the other components test good, it can be assumed that the electronic ignition module is bad. All of the wires need to be isolated from the system in order to get correct resistance readings...in other words, the component you want to test has to be disconnected.<br /><br />Service manuals will have acceptable ranges that the readings have to fall within. Sometimes you can find them at public libraries. If you intend to do your own work on your motor, buying one would be a better idea. There are factory manuals which you probably can't get, but there are a variety of aftermarket manuals available. I like the Chrysler/Force manuals because they take you step by step in easy to understand language, and they deal with commonly available tools and meters.<br /><br />The same is true with magnetos, but condensers aren't testable with common multimeters, unless they're shorted out. You probably have two of everything for a magneto on a twin cylinder. You can sometimes compare readings from like components to determine if one is bad and one is good. Problem is, which one is bad and which one is good? I have also known of flywheels where the magnetism weakens over time. I don't know of any way of testing them, or remagnetizing them. But if everything else tests good, I would suppose that the flywheel is weak.
