Re: water hot
I just did that job, was a snap, there is only 1 impeller available..its the 6 fin model, make sure you pay atention to the direction the shaft turns, the key that holds the impeller fixed to the shaft and get the impeller blades flexed the way they are gonna bend in service when you do the job...I followed the Clymers book and it took about 1 hour, now that I know where all the bolts are (one is hidden inside the exhaust snout, need to remove the snout to get it) I think I could do it in 30 minutes...<br /><br />Oh, and don't forget to remove the shift linkage cotter pin at the top front of the lower unit (the piece that comes off, I was loooking up way too high near the powerhead at first and replace it when done)
