tfbrown1270
- Sep 5, 2003
- 202
Hi...I just purchased a 1985 Princecraft 16 1/2 foot aluminum runabout with a 1989 Force 85 hp. I knew it "might" need an impeller when I bought it but tried to save $15 bucks by running it in a garbage can to check for water being pumped out the telltale....short version of the rest of the story is that there wasn't any water coming out so I ran it for a few minutes thinking it just needed time to prime the pump....I think I overheated the beast...although I never got an overheat alarm. I ran out and purchased the impeller and installed it, when I started it next time it was pumping water like it should, however I noticed water seeping from several of the exhast cover bolts and spraying out what appeared like a vent at the bottom of the exhaust cover (turned out that was a bolt hole with no bolt in it), I took off the exhaust plate and saw the gaskets had failed. My concern before I put new gaskets on relate to the stainless steel baffle; it is warped, I mean it won't lay flat, maybe an inch or so out of flat but not uniform. I would like to know if I should just throw new gaskets on either side of this and bolt it on hoping that clamping pressure will prevent a leak or buy a new baffle (what do they cost?)...it seems they are destined to warp with exhaust blasting on one side and water running on the other....any thoughts would be appreciated.....sorry for the long first post.....<br /><br />Tim (Winnipeg, Canada)<br /><br />Oh....forgot............the shop thought I should replace the head gasket as a precaution so I have one of those on order....
