Just got an 86 Force 50 from an uncle who left it sitting for about 7 years. Starts right up and runs great for about 10 minutes (WOT) then begins to miss, loses power gradually, and finally stops. throttling back once it begins to miss results in very rough low end and rough idle to the point of shutting down. If I sit for 3 minutes it fires right back up and repeats the 10 minutes of fun before missing and losing power again. Have followed this pattern for up to 1-1/2 hours on several occasions. In trying to fix it I have replaced fuel line (and bulb) from tank to engine, replaced both coils, replaced plugs, replaced water pump, tested condensors and points (both are good), and cleaned carburetor twice. Fuel is new, 93 octane, treated with Berryman's and stabilizer. Thought coils were breaking down, then thought it was overheating (based on the sympyoms-- although dropping water on top of engine didn't cause any sizzling) and now wonder about fuel supply. Pumping bulb while running doesn't seem to make a difference. Hope I haven't forgotten anything. Haven't tested compression with gauge, but initially it seems real good.
