1985 force 85 model 856X5L I was wanting to have a look at the water pump to see if visually it is together and no fins missing and such. I have never pulled it before, Do you have to replace seals and that kind of thing when droping the L/U? do I drain the lower unit oil? do I remove the prop? should I wait till I get a new impellor before I check it out? just some generall q's on my mind before I grab a wrench..<br /><br />Thanks
