Re: Adding water pressure guage
U68423, interesting question, I thought about it and feel that a temp guage alone would also provide evidence of water pressure and water flow, if the engine isn't overheating the water flow must be okay, I doubt the internal water pressure is very high in PSI, until the thermostat opens the excess water being pumped in goes out a spring loaded valve. No recommendation on a brand, for long life use one rated for boat use. Good luck.
