I HAVE AN 1988 FORCE 125. <br />HERE IS THE PROBLEM- WHEN I GUN IT THE MOTOR BOGS DOWN. COULD THIS BE FUEL PUMP, OR POWER PACK? P.S. I JUST HAD IT TUNED UP!<br /><br />THANKS- TOM TDVALAINT@AOL.COM
tvalaint,<br /><br />I have a 1988 Force 125, maybe I can help. <br />Can you give us a little more info, Who tuned it, what was tuned, and why? How does it run if you slowly apply full throttle? Do you have a Tach? How many rpm's does it show at idle, and WOT?<br /><br />Could be Fuel Diaphragm or .....<br /><br />KC
KC- THANKS FOR YOUR INPUT! <br />I HAD IT TUNED UP BY OUR LOCAL MARINA. SPARKPLUGS,<br />TIMING AND I'M NOT SURE WHAT ELSE. I DO NOT HAVE A TACK SO I CAN'T TELL YOU AT RPM IT BOGS OUT. I HAVE ALSO BOUGHT A FUELPUMP KIT. MAYBE THAT WILL SOLVE THE PROBLEM.
