Is the hydraulic ram and hose assembly interfearing with something on the boat limiting the range you can tilt the engine? If so, what is hitting/interfearing with what?
Raising the engine would not be the ideal way to try to compensate for your problem. Raising the engine would most likely cause cavitation and lack of water flow for the engine cooling.
Can you post a picture of the problem?
