Re: Motor Has Bad Miss...............................
They are not cheap...but 500 bukz? That does sound steep to me. do some searching online for a good price on one. A lawmower shop is usually equipped and knowlagable enough to change one out. The hardest part (and it could be easy as nothin, or allmost impossable) - is to get the flywheel off.<br />Once that is done, the rest of the way in is easy.<br />But before buying a new trigger, confirm the original is indead, bad. Triggers have coils of wire in them. Just like a coil, they sometimes open when they expand from heat. So coils are suspect too. as are fouled plug, holy piston, blown head gasket, switchbox or a grounded-out plug wire. These will all cause a miss as you desribed.<br />Sometimes an intermittant miss like that, is best found on a dark night with the cowling off. Look for arcing around the switchbox,coils,plugs and plug wires.
