Electric for Force 70 HP 95
toto
Sorry for my bad english.<br />have anybody an electric plan for startswitch of a bayliner 1702 with a force 70 HP 95.<br />i lose All my cable and i dont know wich colour are for which contact.it is an switch whit push to have choke.thanks
roscoe
Re: Electric for Force 70 HP 95
Hello TOTO.<br />I also have a 1995 70hp Force.<br />I have Quicksilver Commander 3000 controls with power tilt.<br /><br />On the back of the ignition switch there are 6 terminals. They are labeled with letters, S-C-B-M-A-M.<br /><br />Starting with the S terminal and going clockwise.<br /><br />Connect the yellow/red stripe wire to the S terminal. This goes to the neutral start switch in the controls.<br /><br />Connect the Yellow/black stripe wire from the engine wiring harness to the C terminal.<br /><br />Connect the Red wire from the engine wiring harness to the B terminal. Also connect the red wire from the power trim switch to terminal B.<br /><br />Connect the Black/Yellow stripe wire from the engine wiring harness to the M terminal. Also connect the Black/Yellow striped wire from the safety lanyard stop switch to the M terminal.<br /><br />Connect the Purple wire from the engine wiring harness to the A terminal. Also connect the Purple wire that goes to the tachometer to terminal A.<br /><br />Connect the Black wire from the engine wiring harness to the M terminal. Also connect the Black wire from the tachometer to terminal M.<br /><br />I hope this helps you.<br />Feel free to ask any questions. I will try to answer them for you.
toto
So many thanks to you roscoe, i have the same Commander and i try it today.One question: you are a member of the second "Stator Club"?<br />Sorry , its a joke but many of German owner of force Outboarder have the second Stator in it.<br />Thanks and spezial greetings from Berlin,Germany
roscoe
No, I'm not a member of the "club." :) <br /><br />I hope Mercury/Force fixed that problem when they upgraded the ignition system.<br /><br />My Great Great Grandfather immigrated from Germany, 120 years ago.<br /><br />Take care or you engine, and good luck.
roscoe
TOTO, did it work?
toto
yes it works,the sun is shining 22 degrees celsius<br />and i take my waterski huuuu no i am waiting the water temp are 10 degrees celsius.
