Re: force/ decarbon
I found my Force doesn't operate worth a hoot with the additive-type of decarb. So I use Valv-Tect spray decarb cleaner. It is sprayed directly into the carb throat with the motor running at fast idle. It smokes up the nieghborhood right nice too.
<br />Just follow the directions on the side of the can. If I can find it, there is a thread by "DUNK", that walks ya thru the dedicated decarb tank method (something I've never done, but heard that it is the most thourough method).<br />Using the spray, you'll have to go thru the process ,as opposed to just dumping it into you gas tank..Whiuchever method you use, instructions are straight forward (at least the ones I have read).
