Re: Power Trim Pump
Hi, okay on the motor running, I then assume you verified the oil level in the pump, low or no oil will certainly cause this problem. If the oil level is okay and the motor runs and there are no obvious leaks but the engine still won't lift or tilt you will need the manual and a 2000PSI pressure guage with appropriate lines to check the pump operation. I was hoping the problem was the motor or control circuitry since that's easier to troubleshoot, you only need a VoltOhmMeter. There are Force manuals available on iBoats or on ebay, use the ebay search function and search on "Force Manuals". Good luck, Ken
