I have a 1986 Force Outboard that runs great. But when I want to start it up, I usually have to turn the key between 3-5 times. Is there anything that I can do to make it start sooner?<br /><br />When I prime the ball, it never tightens up which may be the problem. Also, the choke is rigged up on the key. I have to push the key in while I turn it, to choke it. I usually push it in once and turn, and then do 2-3 more turns without the choke to get it going. Any other suggestions?
