rogerwa
- Nov 29, 2000
- 2,339
I would not rule out fuel just yet.. Did you pump the bulb when the loss in power occurs? You may be sucking air in your fuel line or your carb float may need adjustment. You may also try a different portable tank setup to ensure you do not have restriction in your intake or water or gunk in the bottom of the tank.<br /><br />Also, you may try to run the engine without the cover to ensure you are not leaking exhaust into the cowling. Since you mentioned a problem wiht the exhaust boot it is something easy to look at. This could choke your motor as well.
