stumpjumper
- Jun 10, 2002
- 6
Hey guys I am looking for confirmation before I do something drastic to my prop to test a theory.<br />When I get to a certain throttle position I lose forward motion. The engine tachs out and <br />it is if the prop stops turning. I have a very slow speed and was able to make it back to the ramp under power<br />although it was slow going. I pulled the prop and the shear pin is still intact. I have the same problem in reverse.<br />this is a 76-77 35 HP chrysler. the prop spline shaft is in good shape so I dont think that is slipping. It does not show wear.<br />I have been told that this year motor has a prop that includes a rubber gasket between the prop housing and the<br /> center that fits on the spline shaft and the problem could be that the prop is slipping on the worn rubber piece.<br />I stuck a screwdriver between the flywheel and the starter to prevent the flywheel from moving and could move<br />the prop a revolution in both directions. It wasn't easy to move it but it wasn't too hard either.<br />I was told that a down and dirty way to prevent this is to drill at least three screws through the prop housing <br />and bite into the rubber to prevent the slipping, then perform the screwdriver, flywheel trick again and the prop <br />shouldn't move. Does this sound right?
