Re: Force 15 hp coils
Welcome to iboats, Ron.<br />The blue goes direct to ground. The brown goes to the stop and emergency kill switches.<br />not to confuse you, but the other leg of the kill swiches go to ground.<br /><br />Note, this is on the 89 breakerless (or BIM) ignition.<br />Breaker point equipped is different (so double-check).You should have no points
