Head Bolts for '73 Chrysler/Force
Ranook
My husband and I had a '65 Chrysler/Force 105hp outboard motor that was blown, so we bought a '73 Chrysler/Force 115hp powerhead to rebuild. Problem is, the 5/16 head bolts that we currently have are too small and 3/8 bolts are too big. If anyone has a manual, could you let me know what size bolt it calls for. Or, if anyone has any other suggestions I am all ears.
Terry H
Re: Head Bolts for '73 Chrysler/Force
Ranook...calls for a 3/8" bolt torqued to 20 lbs. The holes in the block may be a little dodgy...you might carefully run a tap through the holes to clean them up...should do that anyhows just so you get an accurate torque. just a Thought
Ranook
thanks a bunch. We'll try to clean it out tomorrow and I'll let you know.
