Re: Force power tilt/trim tilt cylinder leaking
I had the same thing happen to my tilt cyclinder...the one with that crazy collar band.. Goofy set-up in my opinion... I removed cylinder, dissasembled cylinder, drilled and tapped port to accept brass fitting , with NPT threads and installed it into cylinder. Using a die grinder , I carefully removed the portion of the fitting that protruded inside of the cylinder , re-assembled cylinder and re-installed it. Works like a champ, no leaks,...repair costs : $3.50 with new o-ring on piston (while I was in there) why on earth did Force use that silly set-up for the top line ????? I am a USAir Force trained hydraulics/pneumatics mechanic , just so ya know...
P.S. I saved the old collar/ fitting set-up and hung it on our Wally Award board in our shop.....lol
