Re: 1985(?) Force 125 backfiring when starting
signus-x<br />I have an '86 125 HP Force and it back fires sometimes when I start it, but not to the severity it once had. Once you get your motor started and it runs fine after warmup, I would not be concerned too much. Once you get it started, if there is excessive smoke coming out of the exhaust ports, it's getting too much fuel at startup. As for my engine, if I set the throttle (gear lever in nuetral) too high, the engine will 'pop', backfire and run rough. If I back off on the throttle and give it a quick choke while turning the key, the motor will eventually start with little or no backfire. This is my own experince. Your engine may vary. I've consulted a Force expert mechanic of why the engine was so hard to start (not that it was free-the mechanic was relacing a stator at the time). First, the carb settings were off, including the choke plate settings. Secondly, he performed a 'leak test' in each of the cylinders. #2 and #4 cylinders were leaking 90% due to heavy carbon buildup. The piston rings were not flexing the way they should due to the carbon. Yet what was surprising was that the compression range in the four cylinders was from 105 to 115 psi. The mechanic recommended a decarb. The decarbing helped make starting easier along with the carb adjustments.<br />Hope I didn't get too technical on you, but I would suggest taking your engine in to have the carbs checked/adjusted along with a leak test and a decarb. The more you know about your engine, the better for solving present problems and minimizing future ones.
