Re: Force Engine trouble? water Pump??? Help
Yes, as ShadyAde stated, it sounds like the impeller desintigrated as soon as you hit the starter. They do that sometimes, after sitting motionless for a year or so. They also get a bit brittle, and 'trained' into the shape of the pump housing. <br />I don't know what part of the world you are in, but down here in the south,we get these critters that like to build thier homes in the carb and water intakes,called 'muddawbers'.<br />The little rascals can make you pull your hair out. Also,when u pull the lower unit...If you find the impeller has pieces missing, you must find them.Pull the thermostat,and flush the block as best you can.<br />You will need the shop manual, a good compliment of tools,and about 3 hours free time (about an hour any time after the first time).<br />This is also a great time to inspect the lower unit for leaking seals, lube change, and gear damage.<br />see this link for more basic info on the lower unit inspection.<br />
http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=17;t=011919 <br /><br />Good luck.And if you run into difficulty, the guys here will try to help long-distance as best they can.
