Can't find a number on the engine believe it is a mid 70's engine. I need to know if i can eliminate the solid state ignition and just use points. Thanks for any information available.
yes you can distributor guts have to be changed to a point system and a good coil and condenser also. i did it to a 74 105. put a small bead of clear silicone around dist. cap as points don't like salt.
