  #1
Old June 1st, 2004, 09:11 AM
Oldsaltydog Oldsaltydog is offline
Default 1998 Force Mercury 90HP Starter Engages Only Briefly
I have done quite a bit of background research, but I have not found an answer to my particular starter problem yet. Especially when the outboard motor is cold, the starting gear will run up the shaft just fine, but it either will not turn the motor over or it will turn it for a second or two and drop back down again. After repeating this process two or three times, the motor will eventually start. The battery is new and it seems to be charged okay, but I have to admit that I have not checked out all the starting circuit connections yet. (But I have done tons of other repairs on this new purchase.) Any suggestions?
  #2
Old June 1st, 2004, 02:33 PM
JB's Avatar
JB JB is online now
Default Re: 1998 Force Mercury 90HP Starter Engages Only Briefly
Howdy, EBG.You need to troubleshoot the entire high current circuit. It is very likely that you have a low resistance fault in a cable connection. Prime suspect: where the ground cable from the battery connects to the engine block.Check out the starter circuit troubleshooting guide in the "Outboard wont start" article in the Engine FAQ section.Good luck.
__________________
RED SKY at night. . .
JB
  #3
Old June 1st, 2004, 05:28 PM
eurolarva's Avatar
eurolarva eurolarva is online now
As JB mentioned check the wiring for corrosion and tight connections. If connections check out I would first take battery in to an auto parts store and have it tested. A battery can look good and still not have a good cranking charge. For a 90HP you probably want a minimum of 575 Cranking Amps. If battery is fine the next step would be to take starter apart and check the brushes. The hardest part of this is getting the starter back together again because the brushes are spring loaded.Good Luck
  #4
Old June 1st, 2004, 09:21 PM
Thanks for the advice. I did many of the tests you had recommended -- but everything was fine. The problem turned out to be the Bendix gear and spring caked with old gunky grease. After a good cleaning, now the starter works just fine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1998 Mercury 90HP Starter Engages Only Briefly Oldsaltydog Mercury & Mariner Outboards 1 June 2nd, 2004 01:53 PM
1998 Force Mercury 90HP Stalls at Slow Speed Oldsaltydog Force & Chrysler Outboards 3 May 23rd, 2004 10:39 PM
1998 Force 90HP Overheat Alarm Oldsaltydog Force & Chrysler Outboards 2 February 9th, 2004 08:17 AM
My starter engages regardless of key position. kevlar3000 Mercury & Mariner Outboards 4 September 12th, 2001 06:23 PM
1998 90hp Force by Mercury marine repair record mbdlaw Mercury & Mariner Outboards 2 January 18th, 2001 07:37 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
