I have an 89 force 85 on a 1700 Bayliner Capri. I'm getting a little water in the lower unit, just enough to turn the oil a creamy color. I've changed the oil the last couple of times I've been out and the same thing happens. I've changed the gaskets on the vent, fill and drain screws and I still get the same thing. What other seals should I change? shift rod, drive shaft and propeller? <br /><br />I just got this boat this year from my dad and it hasn't been quite properly maintained. I've pulled the carbs off and they're pretty nasty, but I cleaned them pretty well. I also changed the plugs and impeller. What else do I need to change/clean or anything else I can do to keep this motor running well. It runs great now, but I don't want to have trouble with it in the future.<br /><br />Thank's for reading through all this and thanks in advance for any help.<br /><br />-Steven
