Rabbit0074
- Sep 7, 2001
- 5
Please help... This is a new motor for me..<br /><br />I have a '74 8hp Chrysler outboard that does not want to perform. I run it in the barrel and it idles nice, and in forward & reverse it will rev up ok. <br /><br />Once in the water, it will rev up nice with no load, in reverse there is power... However, in forward gear, under load, it will troll ok, but when I throttle up, the rpm will increase a bit then just hold itself..seems to run at half speed. AND after about 5-10 min, it will start surging then die. Through my GPS, I clocked my 12ft aluminum going at about 8km...<br /><br />I have new plugs, points are gapped ok, The sync & throttle seem to be in line.<br /><br />Thanks<br />JCL<br />
