I bought a used 1986 Force 35 two years ago which sat while I finished building my boat. Now that I am ready to start using it I have taken it to two different marine repair places for compression checks. One came out at 100/125, the other at 80/125. I believe it is the bottom cylinder with the lower compression rating. Here is my dilemma. The guy I bought it from says that I just need to run it for a few hours and that may take care of it, that the rings will probably reseat and all will be well. The two repair shops I took it to say its more serious than that. I don't want to go to the expense of a total rebuild, but I also don't want to give up on this motor just yet. Can anyone out there suggest what steps I should take to figure out what the problem is? Probably not a head gasket, since only one cylinder is low. I suspect it is piston rings, but if anyone has ideas as to what else the cause may be and how to diagnose and/or fix it, I would be grateful. I hesitate to run it until I've checked it out a bit more so as not to compound any possible damage further.
