regand2nats
- Jul 8, 2001
- 1
I have a 1990 force 90hp with trouble.The motor starts up just fine when cold and runs great.When the motor is warm and you shift into gear it is hard to keep it from stalling.When you put it in neutral and try to give it some gas it seems slugish and does not gain much RPM.Sometimes I have to put it in neutral and give it some rpms then quickly put it into gear in order for it to run.Once running probably 5mph its great.Any suggestions would be thankful.
