I have a 97 120hp Force on a bayliner 1702 which I have had from new. I'm onto the third set of reed valves!. Is this a common fault with this motor?<br />It has done 176hrs, been serviced every 50hrs and this is the only problem I have had with the motor in over 4 years.<br />The dealer says problem is from over reving<br />causing the reed valve to break. I know I don't over rev the motor, as a rule I generally only get 5000rpm on the tacho and the engine is rated to 5250. I had them check the tacho and it reads correct.<br />Any help will be much appreciated.<br />Alan<br />NZ <br /><br /><br /><br />------------------
