SheepheadShep
- May 8, 2001
- 5
The day I received the boat, it needed a tune up. Not getting any fire in 2 of the 3 cylinders. I replaced 2 CD modules, stater, trigger, and 3 coil packs. Motor ran fine with dog-ears in the yard, took it to the lake, put it in the water, ran it full speed for 1/2 hr, docked at the beach for an hour, started boat back up, past no wake bouy, dropped throttle and it dropped on it's face - maybe 5 mph. The motor would run until 2 of 3 cylinders that were not firing AGAIN loaded up with gas and causing the 3rd cylinder to flood, stalling the engine. I was able to re-start it by replacing the one remaining cylinder plug. It would remain running but still at only 5 mph and no power. Put the boat away for a year and got it out again - replacing the 2 CD modules and same thing all over again. HELP!!!!! Not sure if it's worth working on or getting rid of it. Any suggestions??? Thanks!!
